So you reformatted the drive and then wrote to it?Hi and thanks for your reply, I have tried "RunTime" Software and it is only picking up the program I installed after I reformatted the drive.
Quick format? Then the data is probably still there. You could try GetDataBack.
But if the data is super important i’d use a professional service.
But more importantly why don’t you have a backup?
Depends.Have someone tried Recuva? Does it really work?
