Dat 200
Discussion in 'Home Cinema Buying & Building' started by Worm, Aug 20, 2004.
  1. Worm
    Worm
    Mar 4, 2003
    246
    +8
    Am replacing my old 14" in the bedroom with philips 24" 6518 as I have a 32 6557 idTV in the lounge and its brilliant!. Bout £290 del this leaves me wiv £200 for all in one system and have decide on the LG DAT 200 as it includes freeview . My question is I will be connecting either svideo to svideo or svideo to rgb scart. and will the all in one correctly change the aspect of pictures from the digital receiver. On my lounge set up the dvd player does it correctly and i expect the dvd part of the all in one will. Getting hold of manuals is impossible though eventually found one for the TV
    . Emailed Lg but they havnt replied.
    TIA
