tigermad
Wasn't sure where to post this so will try here since it's the busiest forum.
I have a Thinkware F770 dashcam along with a Cellink B battery pack so I can use parking mode.
It has worked fine for 2 years but since Saturday parking mode does not enable when I turn the engine off. The battery pack has charged up fine and has a green light and no settings have changed on the dashcam.
I have checked the fuse it is connected to in the car and all seems ok. If the fuse had blown I would assume the dashcam would not power up at all anyway since its the only way the camera and battery are connected.
I will try to reset the dashcam later but can't see this making a difference. I don't understand why it would just all of a sudden stop working :-(
