royster said:Is it just my xbox or others that everytime there is a dashboard update my xbox will hang when first switched on. I always have to switch it off and back on and then the update message appears instantly.
stevemac2006 said:Don't wanna' turn mine on now, last time I updated I got the ring of death!
Throttle said:Yea i think its the second update now
Petey said:The only difference I've noticed since installing the dashboard update earlier today is that now my xbox doesn't work. Sometimes it boots up, then the screen breaks up and get like a white noise coming from my speakers. Sometimes it won't boot up at all.
Don't really now what to do now.![]()
Vini said:id be suprised if the update caused that. if it did, youd expect it to just not work, not be tempermental.
Bleeders said:The update bricked my 360!!1!![]()
Everything was working satisfactorily save for a few crashes in Ridge Racer 6 beforehand, however, I ran the update on Saturday morning and that was all she wrote!
Distorted screen for the first few times when rebooting, then the enivitable followed, "ring of death" and that was it. On the horn to MS who confirmed the death of the machine, who then offered to send the cardboard coffin, decided to use my own and UPS should be picking up today, just hoping for a replacement before Thursday/Friday.
Thanks MS!![]()
Bleeders said:Because it was working fine no problems beforehand. Then the update thing appears, run it. Reboot. Distorted picture. Dead.
Check the problem thread, someone else suffered a similar fate I believe, not to mention that MS are supposedly issuing a fix for the update since others have reported problems with it also.
