Das Boot: The Original Uncut Version R1 Review
Discussion in 'Movie Forum' started by Sigismund, Jul 14, 2004.
  1. Sigismund
    Sigismund
    Jan 14, 2003
    5,376
    London
    +102
    [​IMG]
    Edward Marshall takes a look at the original lengthy cut of Das Boot.
    Read his review here
  2. overkill
    overkill
    Nov 6, 2003
    11,778
    Murkeyside
    +1,194
    Cheers sigismund. Anyone seen the "superbit" version?
  3. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,848
    2
    +3,221
    Yeah I own it- it is a reasonable picture and a good soundtrack but you always know you're missing scenes:mad:. I think the only option it to own both :zonked:.
  4. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    I have the superbit version. IMO the PQ is very, very good (just look at the sweat on the 1st officer's forehead - incredible!!!!)
    It is such an awesome film. How wolfgang peterson makes 3 hours go by so quickly is beyond me (and something peter jackson should research!!).
    Not sure if I'll bother with the "uncut" version, though.
    DT
  5. sjp1966
    sjp1966
    Oct 29, 2003
    540
    Kent
    +10
    I must admit i have been pondering over buying this movie for some time now. This new release is tempting but i see that the superbit has DTS sound. Does this make better use of the surround sound as i see there was a low score for the sound in the review.
    I don't really want to own both, but i want good sound, what one is the better to own?
    can anyone advise?
  6. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Well AFAIK all superbit releases use "half" bit-rate DTS (768k) . DD5.1 rates go up to 640k but are usually 448k . But to be honest it seems that the recording/mixing/engineering process has more effect on soundtrack quality than the bit-rate does.
    Given the frequency extremes (esp. at the low end - depth charges) in this movie and your good-quality kit, I can recommend the superbit DTS version. It replaced my "standard" DD5.1 dvd and there was noticeable improvement (significantly less muddy) at the extreme low-end.
    DT
  7. sjp1966
    sjp1966
    Oct 29, 2003
    540
    Kent
    +10
    Cheers turtle, thats the one i shall go for
  8. John-D
    John-D
    Why does everybodies DTS bit rates say 768k? When mine's always said 754k? :lease:
  9. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Blimey, no idea?
    Maybe the rate itself isn't "steady" and fluctuates with the changes in disc temperature/stability? It might be an average rate (the bit-rates of every dvd I own fluctuate - for superbit, anything between 6-10 Mbps, depending on the colours/lighting in the scenery. Dark scenes seem to use lower rates!).
    Just speculation though, better wait for one of the techies to explain properly!
  10. BrianC
    BrianC
    Jan 20, 2003
    2,190
    +101
    erm, that would be the video rate :) which put simply varies for each film dependant on the about of changes on screen, so a high action section should see a higher bit rate than a steady face shot on the leading man crying - within the same film obviously.
    The bitrate average varies from film to film and is dependant at the rate the film was encoded from the orginal source - but this shouldn't been seen as the be all and end all for DVD quality, see the superbit version of Bad Boys, that has a 9/9.5 Mb rate, yet the picture is far from perfect.
    I'm guessing, but I would think that your DVD player is discounting the header and CRC for the audio bitstream, as I think thats about 14 KB? Or another guess, it might be assuming 1024 bits to the byte so its 754 kilobytes rather than 768 kilobits?
  11. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,501
    41
    Central London
    +17
    Yes, BrianC, I was talking about the video rate (not sure if the pio 565 rate includes audio in the "transfer rate" display). True what you say about the PQ/Bit-rate ratio too.
    As for your other suggestions, forgot about the bit/byte situation. I've always found it very confusing and having argued with my boss about it for the last 10 mins! he insists they both use the 1024 convention, (though I'm inclined to disagree with him). I always thought Data transfer rates were measured in bits (with 1024 bits in a kilobit) and storage rates were measured in Bytes (with 1000 bytes in a Kilobyte).
    I'm probably completely wrong here, so can someone please correct me once & for all!!
    DT
