dark smudge in centre of image
Discussion in 'Photography Forums' started by kwijibo, Apr 10, 2005.
  1. kwijibo
    kwijibo
    Feb 4, 2002
    475
    essex
    I have a 300D which has been fine, but recently it has started to show a dark smudge in the centre of the image. I have changed the lense and it is still there, so it is not a problem there...any ideas what it is or how to fix it?
  2. RobertP
    RobertP
    Nov 21, 2002
    529
    19
    Woodford Essex
    Sounds like the sensor needs cleaning. take a shot of the sky out of focus and on f22.
    That should show you any dust on the sensor.
    If that is the problem you need to do some research and decide if you feel confident to do it your self or prefer to send it for service.
    I posted a thread here about my dirt on sensor and cleaning results. I spent a few days reading loads of opinions before getting the right stuff to do the job. DIY is quite easy but in the end it can only be your decision.
