Dark RGB display
Discussion in 'Nintendo Forums' started by Sharpshooter, Oct 11, 2004.
  1. Sharpshooter
    Sharpshooter
    I just got me an RGB cable for my PS2 but when I switch to RGB mode the screen goes darker than it should, so I have to turn up the brightness on my TV. I just wondered if anyone knows why this happens. Is it down to my TV, the cable I use or the settings on my PS2? Any help would be appreciated.
  2. Sinzer
    Sinzer
    May 25, 2002
    5,827
    +1,119
    I have the same problem with my PS2 on just a normal cable. The console brightness/contrast is completely different to my normal RGB feeds from SKY/DVD.
    The same goes for my Gamecube also. Really makes me wish I had a TV where you could save the brightness/contrast settings :(
  3. Lameway
    Lameway
    Mar 29, 2004
    67
    West Midlands
    It's all down to the TV and how it's manufacturered as far as I can tell - a Phillips 28" that's in my lounge has a really dark RGB picture, but the same model that my friend owns is perfect and requires no altering of contrast/brightness levels when switching modes etc.. weird! :confused:
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    JVC have this same problem but you can adjust brightness in service menu to a higher overall level
