Dark red pixels
DJ Dodgy
Hi, I noticed I had a stuck pixel on my lcd monitor and it turned out to be 2 pixels next to each other. I tried the pressure trick to see if it would fix them but am now worried about what that did.
You know that lighter screen patch you get after applying pressure that fades away? Well I noticed that after doing this, quite a few pixels (only visible during the lighter pressure patch) were a dark red color. Wherever I put pressure, they would appear. Also they are only visible on a black background.
They are not visible during normal use, but I'm worried that I've damaged the screen or something. :(
Will the reddened pixels be ok?
(Monitor is an Alienware Optx AW2310 btw)
