Dark cloud spot on Samsung 75”
duckson
Had the Samsung 75” TU7020 since September and have noticed a dark cloud spot appear within the last few days that is visible on white or lightish backgrounds.
I’m sure it wasn’t there previously and it went when I messed with the settings last night a bit!! Turned it from Filmmaker to Dynamic mode and back but today it is still visible again and doing the same has no effect seemingly.
Is this a known problem that can occur or was it likely there from new?
I’m obviously in the 12 month warranty window and I bought it with 5yrs warranty but might of messed up and not registered it with Samsung (can’t find any correspondence).
tvdavid
hope you get a replacemnet
rccarguy2
Probably failed backlight led. If you had way to test each backlight led in turn can determine if that's the case
Samsung S95B Update, B&W Panorama 3 & Q Acoustics Reviews, HDR PQ EOTF/Gamma Calibration Discussion
