Dark bands/lines on my LCD, picture included
Discussion in 'LCD & LED LCD TVs Forum' started by Hue Jorgen, Aug 28, 2006.
Tags:
  1. Hue Jorgen
    Hue Jorgen
    Hi folks,
    I asked this question the other day on here, but didnt get any replies.
    I realised i needed to take a picture of the problem, because it just sounded strange in words.
    Any way, ive had my Aria LCD about 2 months, i have been delighted with it so far, but the other day when watching the football, i noticed a thin dark band just bellow the centre of the screen. After a bit of changing inputs and so on, i realised it was there all the time, unoticable most of the time, but football or golf show it quite clearly.
    I thought it must be my wiring, so i unpluged everthing, moved the TV to a different room, with no source connected, messed about with the setting, turning up the brightness to full, you can make out 4 clearly defined darker bands running left to right, about a quater of an inch thick, finishing about half way in.
    Im no expert, but this looks as though it has somthing to do with the backlight.
    I cant understand why i hadnt picked up on this before now, because i had run the Avia setup dvd, watched some of the World Cup, and never noticed it once, now i see all the time.
    It may have been there from new, but could it of devolped? Or is this a normal feature for an LCD panel?
    Is this a fault?
    Any advice or coments would be most welcome.
    Thanks Carl..
    [​IMG]
  2. azirath
    azirath
    Jul 23, 2006
    43
    That kind of thing is common on older LCD monitors at least(havent bought one in a while :)
    As to why you havent seen it before it might be because you were running on lower brightness or because the backlight changes after a little after being turned on. I remember some people testing this with some Dell monitors taking photos similar to yours after turning it on, after 10 min, 1 hour etc.
    What you are seeing is probably the backlight itself, how visible is it at normal brightness?
  3. Hue Jorgen
    Hue Jorgen
    Hi Az,
    You can not see this on a black / dark screen with the brightness set to 50%, its only visable when a brighter more uniform image is displayed, i.e. a football pitch.
    The TV is suposedly using a Samsung panel, its the Aria special at £480. Other than this i couldnt be happier with it.
  4. Hue Jorgen
    Hue Jorgen
    Please can anyone tell me if they think the above is a fault.
    I need to know soon as I will ask for a replacment or fix from Aria, but i dont want them to give it back to me, with them saying theres nothing wrong it.
    TIA Carl..
  5. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Na, not a fault.
    It's just in modern standards a poor panel. What you are seeing is definatley the backlights.
