kenshingintoki
Hey guys, so I've bought my house.
I have a 'dedicated' space available of 4.4M x 6M (okay it can be 6.5 or 7M) as I'm doing an extension.
However, I am not happy for it to be 100% dedicated as I'm extending and designing it from scratch so want it to first and foremost look really nice, rather than it be a dedicated film viewing space.
I want to try and combine
1. Dark moody living room
2. A bar type vibe/setting with ambient light
3. the latter half/third being a home cinema room
Therefore a compromise has to be met. I'll post drawings later. I have chimney breast which will occupy the first third of the room and I for a short while thought about knocking it out but I've decided to dedicate the first half of the room to a whiskey drinker/traditional fireplace seating area as TBH I want the room to look beautiful, more than I want it to 100% light control for my HT lust.
I'll likely keep with an ALR to minimise the small amount of reflected light still there. GOd knows where the architect will choose to put windows.
These are my design inspirations for the room to let you guys see where I'm coming from:
Design ideas:
1. I have fairly tall ceilings so I'd like to ideally have the projector on the top shelf of a custom made bookshelf rather than ceiling mounted, at the back of the room.
2. I aim to have some leather tub chairs near the fire place for a seating area with a semi-precious little table.
3. I am to try and fit like the guy in video 1 has, bar area with whiskey and controlled with some back lighting.
4. I hope to have my rear speakers in the custom made bookshelf cabinet too.
5. The second half of the room will have a four seater long sofa, with the hoverBOSS underneath. The people form the tubchairs will hopefully be able to still see. I might sack off the hoverBOSS if it doesn't fit the aesthetic of the room, in which case I'll sell the parts I gathered. I might have a few single chairs at angles beside the four seater too for additional seating.
6. The screen will be ceiling mounted and electric coming down and ALR with an OLED TV behind it. I am not doing acoustically transparent because I need a TV.
7. wall facing the audience with the projector will obviously have the arendals, all the gear and a subwoofer. I REALLY like the look of my arendals in this dark moody room so I'll probably not need to hide them.
8. The wood panelling from the second video I am very eager to use a feature wall. I have no idea how. Ideally I want it around the whole room but everyone I've asked says I should only do it on one wall. Otherwise I might just go for the detailing in video 1 as IMO it looks very.. moody.
Any ideas or suggestions on improvements and any design inspirations?
Design ideas:
