norfbech
Hi all,
Daughter ordered some Daqus bluetooth headphones as linked below:
DAQUS Bluetooth Headphones
These were to replace a Sony WH CD700n pair (which were actually relatively new and not used a great deal). We'd lost one of the signals from the ear and despite doing all the factory resets and me taking them apart and multi meter testing the wires (which seemed ok) but could not find a fault. I suspect it's in the main driver but this is all sealed up would need breaking open, ordering a new one and a bit of soldering I presume. Out of warranty but there might be an option for these to be fixed at a cost....which given I may have to return the Daqus above might be the better option?
The Daqus in question have a delay on video - at least 1/4 of a second and as my daughter mainly uses these for videos they've fast become intolerable. Nothing I can do has been able to fix it. I've read that it's probably down to low latency issues and that a possible fix would be an adapter (btw - the main use is headphones to either iPad or iPhone rather than TV) but is that even feasible with an iPhone or iPad given the lack of connections on those (never mind adding bulk)?
Many thanks.
Many thanks.
