dansai handset hack for multi region
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by pat clancy, Jan 9, 2002.
  1. pat clancy
    pat clancy
    Sep 10, 2000
    1,832
    LONDON
    +30
    how do i make this player multi region and disable the macrovision
  2. harris87
    harris87
    Mar 17, 2001
    35
    united kingdom
    hi ya there,
    to make your player multi-region,and also diabling the macrovision
    1 press set up on your remote control 2 press the stop button 3 press the previous button
    4 press the next button
    you should see a factory set up screen on the tv.
    you will be able to toggle between which regions you would like.
    hope this helps..
  3. pat clancy
    pat clancy
    Sep 10, 2000
    1,832
    LONDON
    +30
    thanks for the hack,works fine,i must say what a good dvd player,it even plays my photo cds
  4. harris87
    harris87
    Mar 17, 2001
    35
    united kingdom
    i am glad your hack works.
    had this player a few weeks ago and had to change it three times.
    because i was using to to audio cd's i noticed when playing through a hifi i noticed the sound was louder on the left channel more than the right.
    anyway glad your hacks..
  5. chrisp
    chrisp
    Jan 6, 2002
    64
    9
    Essex, England
    Hi guys
    Is this the Tesco machine?
    Will it play RCE DVDs?
    Any know issues other than the audio CD issue mentioned?
  6. pat clancy
    pat clancy
    Sep 10, 2000
    1,832
    LONDON
    +30
    yes crisp it is the tesco one,my local just got a big delivery in feltham,there are so many setting for this machine,left mono,right mono,but i must say i,ve had no problems,plays mp3s very well,cds are fine too,multiregion,and macro disabled,i recorded a rented dvd today,great,for £99 a steal,dts is brilliant.i was a bit worried about buy this machine,as i had a pioneer 515 before, i cant honestly tell the differance,maybe just a bit on cd playback
  7. chrisp
    chrisp
    Jan 6, 2002
    64
    9
    Essex, England
    Thanks for the info Pat.
    Took a look this morning but it's only a 2CH machine and as my amplifier doesn't have an optical input option (it has 6CH phono input) it's a no goer for me.
