Dansai 952
Discussion in 'Blu-ray & DVD Players & Recorders' started by macca56, May 24, 2002.
  1. macca56
    macca56
    Does anyone know the hack to the above dvd player(both macrovision and region) thanks in advance
  2. pat clancy
    pat clancy
    Sep 10, 2000
    1,833
    LONDON
    +30
    i had a dansai,not sure which one,the hack,press setup,then stop,then next,then previous and you get a menu,hope this helps
  3. macca56
    macca56
    Thanks m8 it is for my son i will get him to try it
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. macca56
    macca56
    The region free hack works, not sure if macrovision is enabled when i have tried to tape there is minor discolouration on the video it seems a few others on different forums are seeking the same solution to this dvd player Thanks for the link quite interesting to a newbie like me
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    No problem man, have a coconut
