Dansai 952 - Help Needed
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mwillo, Jul 26, 2003.
  1. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    I have a Dansai 952 player, I was messing around with the video output in the menu, now all the I get on screen is a rolling picture. Is there a way to reset the player back to factory defaults with a keypress at powerup.
    or
    Can someone give me a key press list so that I can set it back to original settings blind...
    Thanks in advance....
  2. simonb68
    simonb68
    Dec 16, 2002
    229
    Bucks
    +3
    Mwillo, I take it you don't have the manual?
    On the remote
    V-MODE switches between Composite and Scart
    P/N cycles through AUTO, PAL & NTSC
    Though it sounds like you have changed the VIDEO MODE in the menu
    To alter these, key presses should be
    MENU - General Setup is selected
    PLAY - inside General Setup menu
    DOWN x 3 - Video Mode is selected
    PLAY - inside Video Mode sub menu
    This menu contains
    RGB
    YCrCb
    VIDEO
    You can now try going up/down and selecting to see if that fixes anything.
    If all else fails a Factory Reset can be done with the following keypresses
    DOWN x 4 - Preferences is selected
    PLAY - inside Preferences sub menu
    DOWN x 5 - Default is selected
    PLAY - inside Default sub-menu
    The only option in here is RESET, I assume pressing PLAY performs the reset, never done it, so not sure.
    If this doesnt work, let me know, I'll try it myself.
    Hope that helps
  3. Mwillo
    Mwillo
    Feb 15, 2002
    139
    Liverpool
    cheers
    its was the video output i changed, so thankyou for your help.
    the key presses work a treat.
    mark
