Damn SONY DX100.
Discussion in 'General TV Discussions Forum' started by zcaps57, Jun 16, 2002.
  1. zcaps57
    zcaps57
    I got a SONY KD-32DX100 delivered on Friday.
    It looked "new". (no scratch, no dust on screen at all. And manual & remote were sealed in a plastic bag.)
    Well.... the unit had a bit of geometry problem. (I tested with AVIA.) So I went into service mode to to fix the geometry.
    The timer was at 114 hours. :(
    If this timer counts testing/setting/optimising in a factory, I wouldn't worry about it.
    If I didn't see the timer, I wouldn't doubt for a second at all. The unit looks that new.
    Oh, BTW I fixed the geometry problem. It isn't 100% perfect, but very good for CRT. I can't expect 100% perfection from CRT anyway.
    Anyway... could anyone comment/advise on the timer please ?
    I'm not sure if I should exchange it. :(
  2. Big Jim
    Big Jim
    If it works and looks fine with the geometry sorted, don't risk exchanging it for one that might have more problems...
  3. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    zcaps57,
    I too bought a DX100 and wasn't 100% happy with geometry. After having it a few days I went into the service mode. I checked the timer and found it reading 100+ hours. I had to estimate, having already been running the set myself, but guessed it must have been arround 110 hours.
    Had the set exchanged. Checked its timer before even tuning in and found 112hours 35 min. Make of that what you will.
    What date is on your service menu? Mine is 5 March 2002.
    What items did you adjust to improve geometry?
  4. Squirrel God
    Squirrel God
    My Sony KV28LS60 had a service time of zero when it was delivered (I checked it within 30 minutes of turning it on for the first time).
    Before that I went through 2 Philips sets (28PW6515s) and they both had a service time of approx 100 hours (I can't remember exactly now, but it was definitely not zero).
    Weird. :rolleyes:
    Maybe factory setup is included on some sets (including firmware upgrades perhaps). As the LS60 is a newer model, maybe they reset it after setup... who knows :confused:
    Have to agree with Big Jim though. If everything else is okay, 100 hours isn't so bad to deal with.
  5. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    Given that these timers on both our DX100's (inc my replacement) were arround 100 hours, suggests it is likely due to testing, rather than previous owner. I feel quite confident in this.
  6. fwan
    fwan
    !00 hrs of testing ???? At this rate, SUK will need a factory covering half of Wales !!!:confused:
    fwan
  7. Squirrel God
    Squirrel God
    100 hrs might include a "run-in" time as well though?
  8. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    I hadn't thought of it like that. Yeah, imagine all the sets comming off the production line and each one is hanging around for 100 hrs before it can be boxed.
    Mind you, if it had been tested for 100+ hours, you'd think they'd get the geometry spot on.
  9. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,379
    Somewhere in South Yorkshire
    +5,766
    100 hours (irrespective of how it was caused) is nothing significant.
    Of much greater significance is the geometry and other artefacts of the picture. If yours is good (ie - to your satisfaction) then keep it.
  10. steaming g.
    steaming g.
    SG - just bought a KV32LS60 (v. happy so far).
    Where in the menu can I find out how long the set's been running? Had a quick look but no success. :confused:
  11. Squirrel God
    Squirrel God
    It's in the service menu, not the user menu. You have to enter service mode, and then it's under the last service menu item ("error" something or other) ;)
  12. steaming g.
    steaming g.
    Squirrel
    Call me stupid but how do I enter the service mode?? :clown:
  13. Squirrel God
    Squirrel God
    Put the TV into standby.
    Then press the following on the remote:
    i+
    5
    volume +
    TV (just under the red teletext button)
    The TV will come on and you will be in service mode. Press the MENU button on the remote to display the service mode menu. The last option in the list is "Error" something or other. Highlight that and then press "-->" on the remote to display the list of errors and the total service time.
    Press MENU to get back to the menu.
    To exit service mode, just turn off the TV from the remote (i.e. put it back into standby).
    If you haven't been into service mode before then... note that you go into service mode at your own risk. Be VERY careful - one false move and you could screw your TV up!
  14. Marvinius
    Marvinius
    Feb 11, 2002
    47
    11
    On the Beach
    All,
    some of you may remember my posts from 'fq 75 scrolling bar fame'. i was one of the 'lucky' recipients of a replacement dx100 18 months ago, (which by the way had exactly the same fault but no where near as bad as the fq..i decided to olive with it. 18 months on and the damn thing has died on me! completely and utterly dead! i am on a colling down period, and will be speaking to my good friends SUK tomorrow....anyone else experienced the same? BTW Fwan what was your outcome in the end?
    Marvinius
  15. Paul Atreides
    Paul Atreides
    Ageing time is measured separately.
