Damn RGB!
Discussion in 'General TV Discussions Forum' started by micflair, Dec 28, 2001.
  1. micflair
    micflair
    Oct 12, 2001
    268
    +5
    Okay, just a wondering... Ive got my Sky Digi, OnDigi, DVD Player and PS2... all RGB yeah.. with ONE RBG scart... which one do you guys go for? I tend to swing towards whichever you use the most.. but what does everyone else go for??
    Mick
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,197
    +1,241
    Everything just use switchboxes.
    I favour the scart data-switch boxes from lektropacks as they are good and chunky and well shielded ( and work as switches in both directions) . however you can get boxes from as little as 10quid: Argos do a couple .
  3. micflair
    micflair
    Oct 12, 2001
    268
    +5
    Yeah.. I was thinkin of one of em.. have one here with 2 sockets on.. need one for 23893829 sockets :) Cheers mate, I wish there was remote control ones though :)
    Mick
  4. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Yes whatever you do use RGB on everything, especially as you have a RP TV. Forget Composite on these beasts. S-Video is OK but no where near as good as RGB.
    BTW, they do remote control SCART switch boxes...
    Check Out
    http://www.keene.co.uk/
    If you're going to get a manual one (I use one), make sure it is RGB compatible. Not all are.
  5. micflair
    micflair
    Oct 12, 2001
    268
    +5
    Hmm, is the one from argos RBG compat does anyone know??
    Mick
  6. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Yes, I think it is, but AVOID. My m8 had one and there was interference between the devices.
  7. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Stay well away from the one from Argos. Bought my oblivious parents one because it was annoying me that they were sacrificing RGB from cable Tv for the DVD. It's supposed to switch between three sources, but leaks RGB signals like a sponge bucket. It's OK for my parents, because they are more than happy to turn the other thing off while watching one. For everything you mentioned above, it's out of the question.
    Personally I'll be treating myself to the Quattro+. Costs about £80 but you can run three RGB signals through to one and switch between them without leaking. It's remote control switching too. Life will be so much easier....
    http://www.lektropacks.co.uk/acatalog/quattro.html
  8. micflair
    micflair
    Oct 12, 2001
    268
    +5
    Cheers mate.. might get the old credit card out then :))
    Mick
  9. toshrpowner
    toshrpowner
    :confused:
    pointon that Quatro+ switch box sounds good but looking at the web site this box does not relay the wide screen signal to the tv, so you would have to manually change the screen size all the time :mad: . Any ideas on a switch box that can relay the signal and handle many RGB signals at once?
    TA
    tosh
  10. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Aye, this is a downside, but it's a small one compared to the connection convenience gained. Most widescreen TV's already have auto detection anyway, and true widescreen signals from DVD's and genuine widescreen channels such as Sky Premier Widescreen tend to be recognised easily enough by my Panasonic to satisfy me.
    I don't know of anything else like the Quattro+, nevermind something that would support automatic widescreen switching. Unfortunately.
    If only manufacturers would give us more than just one RGB enabled input!
  11. Doubledoom
    Doubledoom
    The auto detection on the tv is handled via pin 8 on the scart from skydigital. So not having widescreen switching via the scart would not allow the tv to guess.
    Many dvd players and many televisions will also use Line 21 and line 23 WSS to put the tv into the correct mode. So scart switching isnt needed for this.
  12. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Well Games console daisy chained through DVD player on RGB, vcrs on other Scarts.
    Got an IDTV - frees a Scart
