Damn my sky+ luck!
Discussion in 'Sky Digital TV Forum' started by MrFurious, Mar 4, 2003.
  1. MrFurious
    MrFurious
    Sep 9, 2000
    14,320
    Cardigan Wales
    +1,556
    The installer just put it all in,set it up and yes you guessed it,it does not work,it will not record or act at all like a sky+ box!!!Fair play to the installer he tried his best to get it working but no way,they are coming back next wednesday to replace it,so much for this free trial,the installer also told me that with the free trial they send out old boxes from the first wave of release!!!He said that if i decided to keep the sky+ that he comes back and installs a new box.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Seems reasonable to use old/used hardware for the trials to prevent new hardware from being soiled but you'd think they would make sure they worked before sending them out!
    Not the best introduction to SKY+ is it:(
  3. MrFurious
    MrFurious
    Sep 9, 2000
    14,320
    Cardigan Wales
    +1,556
    installer just left and the new box is working,spend the afternoon playing about now,i read somewhere that you can manually tune radiostations in,is this true?
  4. DaveP
    DaveP
    I think you may have confused the manual adding of ITV regions with the manual record feature that allows you to record radio programs!
    You cannot "tune in" radio stations, they are on the EPG.
    DaveP
  5. MrFurious
    MrFurious
    Sep 9, 2000
    14,320
    Cardigan Wales
    +1,556
    thanks for the advice mate
