Was just getting round to put the cable tidys on the cables when i pulled out the power cord from my ntl pace box ( by mistake ). Now when i put it back in ( we are talking milliseconds ) Sky one had gone all blank, cant get picture or sound, also on some of the movie channels, So will it be easily repaired or time to get a new box...
Are cable boxes rented , as opposed to owned like Sky ones ? I guess you provider will just replace it JS
what modification did you do? can you reverse it? otherwise look at a code to reset the box, it should retune everything, if something knackered the power then id imagine it would of blew the entire box
