damaged tweeters on celestion 3 mkIIs
Discussion in 'Home Cinema Speakers' started by frazer, May 9, 2005.
  1. frazer
    frazer
    May 9, 2005
    10
    I picked up a pair of Celestion 3 MkIIs on eBay, both of which have dents in the metal tweeters. On testing them, one seems fine, but the other makes a terrible crackling noise- rather like a badly tuned radio- on louder, higher pitched passages; particularly noticable, for instance, in the sustained top notes of the soprano voice (I mainly listen to classical music!).
    Given that both speakers seem equally dented, yet only one has this problem, is it likely that these dents are the cause? If so, is it advisable simply to push them out again- the metal is very pliable- or would they need replacing?
    Thank you very much for any advice,
    Frazer
  2. deanym
    deanym
    May 29, 2004
    1,786
    +141
    There is a thread where a member had a similar problem and popped the dents out. Try it on the crackling one first, if it solves the problem then great if not, then you've lost nothing and the investgation must go further. If its easy to do, try swapping the tweeters in each unit around and if the same loud speaker is crackling with the new tweeter its the crossover, if the other one crackles then its the tweeter.
    Kef and Celestion have a joint spares system, so if you do need a replacement just contact kef and explain what you want, I've dealt with them in the past and they were brilliant.
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I think it's definitely worth getting a quote for replacement parts, the swapover should be really easy and then you'll know that you're definitely getting the best from them. :)
  4. frazer
    frazer
    May 9, 2005
    10
    Thank you very much for the replies.
    I must admit I suspect that the dents won't be the cause of problem (despite what I was told in a repair shop), as the nature of the interference to the sound is not what I would expect, and nobody else with similarly damaged tweeters has reported such an obvious reduction in sound quality. But then I'm no expert at all, so it is probably worth having a go at fixing the dents, if I have nothing to lose, and replacements would not be too expensive anyway.
    I presume fixing problems with the crossover would be harder, or could it just be a question of dodgy wiring?
    Thanks again,
    Frazer
