Damaged LCD
Discussion in 'LCD & LED LCD TVs Forum' started by fenpark15, Sep 24, 2005.
Tags:
  1. fenpark15
    fenpark15
    I recently bought a used LCD. It's only problem is that in the bottom corner, it has a dark "shadow". The picture shows there, but it is darker than the rest of the screen. Is there any way this can be repaired? What is most likely the problem? Is there an estimate as to what it would cost to get fixed? Thank you!
  2. BestGear
    BestGear
    Oct 22, 2003
    1,188
    +42
    ...sounds like the screen has had pressure applied to it at some point... and no, I think you will have to live with it....
    DJ
