Damaged KEF speaker
CptBill
Hello guys,
I own a pair of KEF Q55 speakers. One of the speakers recently appeared to have a problem. The problem is on the dust cap of the speaker. I contacted KEF UK and the KEF local distributor and they suggested me to re-glue the dust cap with impact adhesive.
A photo of the speaker can be seen here:
Is the "re-glue" solution the right one?
T
Tejpal
Try the glue, if it doesnt have satifactory results, you might have to purchase a new driver of kef, which will cost alot of money.
Is the dust cap damaged ?
CptBill
No damage except the part that has "detached" (not sure if that's the right word).
T
Tejpal
just curious how you managed to remove it, they are normal stuck on with strong glue....
gringottsdirect
Personally, re-attach the speaker grille, forget about it.
That particular dustcap design isn't a cone stiffener being soft, it's only of cosmetic significance.
CptBill
I didn't remove it. One day i just saw it removed.
Similar threads
