Damaged Hearing Courtesy of YSP-1
Discussion in 'Home Cinema Speakers' started by kmhtkmhtkmht, Sep 8, 2005.
  1. kmhtkmhtkmht
    kmhtkmhtkmht
    I've owned and am proceeding to return the Yamaha YSP-1 cause it's been detrimental to me and my partners hearing.
    After just a couple days of use, maybe cause it's tricking your mind into thinking there is stuff behind you when it actually does work, and now has resulted in my hearing feeling very hollow and uncomfortable.
    I have made appointments for me and my partner at my GP and want to get this checked out, I thought it was just me to start but then when the girlfriend also concurs that it feels like "there's constant water in my ears" then I know it's not just me.
  2. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    Sounds creepy! Good luck...strange story, would think they would try it out themselves for a while you should guess?
  3. recruit
    recruit
    kmht - Are you being serious ?
  4. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Hmm, i have heard of hairs standing up on the back of your neck, but water behind the eyes? Perhaps Piriton or maybe a spoon in your mouth?
  5. kmhtkmhtkmht
    kmhtkmhtkmht
    Nah that's how she describes her ears!
    I describe it as being really Hollow and you have to constantly Pop your Ears.
    I've packed it back up and am using the TV Speakers on the Sagem HD-D56.
    I am being dead serious!
  6. Gary_W
    Gary_W
    Jun 6, 2005
    450
    +21
    Whilst I am no fan of the YSP-1, it is far more likely that the pair of you have picked up a minor ear infection of some kind that is totally unrelated to the new speaker. The sensation of having water in the ear is a common one with ear infections / blockage of the eustation tube. The only way you would damage your hearing with a loudspeaker is constantly turning it up too loud, and if you do that then ringing will be the first thing you notice as opposed to water.
    For the record, the YSP-1 does not 'trick' your brain at all. The sound really does come from behind you / beside you due to the fact that it is bounced off the walls. It is sending these sounds out a bit before it would were they travelling down a wire to an actual speaker to allow the sound time to propogate and reflect. Not 100% effective IMO but it's no more likely to damage your hearing than a budgie breaking wind is likely to cause a significant sound pressure wave in a 20 foot room.
    I suggest you get the doc to check your ears out (ear infections can be deeply unpleasant) but I'm sure he'd be as bemused as me to think that a fairly low output speaker could do this to you.
    Gary
  7. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    You might be sensitive to phase anomalies. An extreme example of this is listening to headphones with the channels out of phase, this gives me a similar sensation. It is quite likely that one of the ways the YSP-1 generates its surround sound effect is by manipulation of interchannel phase. You can also get phasing effects like this if you have very unequal path lengths for the theoretical reflected sounds.
    As Gary says, it is high sound levels that damage your hearing, and similar effects can be produced by infections, colds etc.
    Bill
  8. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Isn't that something that Captain Archer and the crew used to have problems with every week ?
  9. recruit
    recruit
    kmht - I would be interested to know what Yamaha have to say about the Damage it has caused to you're ears and i presume you are going to speak with them and follow this up as you are quite convinced that it is the speaker that has caused this problem ???
  10. Weidass
    Weidass
    Jan 5, 2005
    104
    Cambridgeshire
    yes it is. all you need is a Flux Modulator and a phase inverter. then ur sorted.
  11. kmhtkmhtkmht
    kmhtkmhtkmht
    Well, I have the appointment with the GP soon so we'll see what comes out of that.
    It go so bad that when people were talking to me I had to read their lips to understand what they were saying.
    I will be contacting Yamaha and seeing what their chat is, and whether this has ever happened before.
    It's a shame really cause the thing looks pretty cool.
  12. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Surely that's a flux capacitor?
  13. kid rock
    kid rock
    Dec 10, 2003
    316
    frankfurt germany and cardiff wales
    +9
    What volume are you playing at? Even at a constant volume of 90 - 95dbs hearing damage can set in and with modern av equipment these levels are easily achievable and the louder you play the more used to it you get.
  14. kmhtkmhtkmht
    kmhtkmhtkmht
    It wasn't the Volume at all, I am convinced it was the YSP-1, I played stuff at about 25 - 40 dbs...
  15. Weidass
    Weidass
    Jan 5, 2005
    104
    Cambridgeshire
    u mean -40 to -20 on the amp right? cos 20db is a whisper.
  16. sallyann
    sallyann
    So have you seen the doctor yet? I'd really like to know the outcome as I have been considering getting one of these.
  17. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    Colour me sceptical. I really don't think that any sort of speaker played at reasonable volumes could 'make' your ears go funny like that. Like GaryW I'm betting on some physical cause - call Dr. House!
  18. rhubarbe
    rhubarbe
    May 25, 2005
    4,668
    Cheshire
    +211
    Yeehaaaa!!! It's the Song of the Compo Cowboy...
  19. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    no silly a flux capacitor lives on a delorean.
    kmhtkmhtkmht :rotfl: are you for real. duh
    sulis more likely mental than physical
  20. Peteee
    Peteee
    Hi Km
    Did you return your YSP1
    Where did you get it from as I am looking for a supplier
    Hope your hearing is better
  21. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,001
    Southampton
    +233
    Guess his Doctor must have a full appointment book ........
  22. KBDVD
    KBDVD
    Aug 25, 2002
    714
    Hertfordshire
    +6
    Or a waiting room full of "Mutton" YSP-1 buyers! :rotfl:
    DOCTOR: "Ok, I'm going to have to syringe your ears, but don't worry it's not like an injection",.......... "You won't feel a little prick!"
    kmhtkmhtkmht: "Want a bet!" .......... "Eh? What did you say?"
    DOCTOR: "I said, ... You might squeel a little bit!"
    DOCTOR: "Next,.............. Next, ............... I SAID NEXT!
    ................ Honestly, what a load of old tosh,........ I've heard it all now! ....................... Mind you, that's probably because I have yet to buy my YSP1! :rotfl:
  23. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    13,820
    2
    167
    Birmingham, UK
    +9,554
    KBDVD, please do not be so distrspectful.
    Could you please not get yourselves into trouble by speaking your mind with the wrong selection of words about what kmhtkmhtkmht is saying?
  24. KBDVD
    KBDVD
    Aug 25, 2002
    714
    Hertfordshire
    +6
    Hi Stu, :hiya:
    No offence intended, ..... just having a wee laugh! :D
    My apologees kmhtkmhtkmht. I hope that your hearing problem proves easy to resolve.
    I have a "ringing in my ears" but I just attributed that to being married! :rotfl:
    ps: If you decide to sell your YSP-1 let me know as I might be interested in buying it! :smashin:
  25. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    kbdvd....... :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :rotfl: :nono:
  26. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,071
    The Borders
    +2,529
    Hello Stuart
    I would have though the direct attack on Yamaha and its products on your Forum was a bigger 'issue' than KBDVD poking fun at someone who says one thing on lots of threads and then does an overnight 360 swivel in lots of others.
    Best regards
    Joe
  27. recruit
    recruit
    My exact thought's too, it does seem kind of strange and quite a big accusation towards Yamaha :rolleyes:
  28. Not A Clue
    Not A Clue
    :rotfl: Lol! I was a bit miserable after my kop heros 0-0 with utd but this thread has brought a smile to my face - flipping hysterical :rotfl:
  29. KBDVD
    KBDVD
    Aug 25, 2002
    714
    Hertfordshire
    +6
    Thanks Joe & recruit! :smashin:
    You make an excellent point!
    I stand by my apologee to Stu & kmht as I really did not intend to cause any offence, and was just poking a bit of fun at kmht's outrageous claim, but I had thought exactly the same thing myself! :devil: I know that if I were Yamaha UK, I would not be too impressed with seeing a thread on here that was running under such a title. :mad:
    How can a thread entitled "Damaged Hearing Courtesy of YSP-1" be allowed to remain unchallenged? :confused: I would have thought that at very least an "alleged" would need to be added! :lesson:
    I too had spotted the apparent 100% turn-around in kmht's YSP-1 threads, but despite this, the fact remains that he does appear to be totaly sincere in his belief that the YSP-1 is to blame for his hearing problems! ...... Even if everybody else on here probably believes that the chances of this being the case is, erm, ..... how do I put this now? ....... Round, dangly and sounds like a group of young male calves! :D
  30. ijd
    ijd
    May 20, 2005
    2,166
    63
    +129
    actually the very title of this thread leave avforums wide open to libel, it is as we all now totally unfounded and unjust as well as absolute lunacy, and as there is no proof the said hearing problems were caused by the sound system....well you do the maths,if the claim was not so outragiously funny then it amy well be a differnt murmering going on in this thread
