dam!! decision thrown into turmoil!!
Discussion in 'Plasma TVs Forum' started by adymartin, Feb 9, 2005.
  1. adymartin
    adymartin
    Jan 27, 2005
    130
    16
    dam!! went out last night to view a panny7 and ended up finding one on display next to a phillips 9946.
    the philips looked decidedly better in the store, both were running the same demo DVD various different television show clips, when the demo for the pixel plus came on the screen for the philips i thought it looked a bit grainy, but nonetheless, it looked better all the way through, panny looked very blocky for some reason. then we swapped the dvd for star wars, and star wars looked awful on the panny, philips again looked really clean and smooth.
    whats the story here do you think? settings?
  2. deanym
    deanym
    May 29, 2004
    1,832
    +142
    The panny is the better screen, perhaps it was set up with the weakest connections. The later philips' units are getting better but the '46 is rather weak.
    A panny 7 with the relevant connection boards etc will be better in every aspect against the philips.
  3. t0by
    t0by
    Jul 27, 2004
    455
    Hertfordshire
    +7
    ady, if you do end up plumping for the Philips, I just posted a thread about them being £250 off at CostCo...
  4. Stuart.Ainslie
    Stuart.Ainslie
    Nov 20, 2004
    127
    16
    Little Clacton, Essex
    Replaced a Philips 9946 with a Panasonic PW7 - In a different league really.
    I agree that in the shops, the Philips looked good but when set up at home it was pretty much unwatchable.
    Just my opinion though......
