Dali Fazon Rubber Gone Sticky
thewhirlwind
Have a set of 5 Dali Fazon satellite speakers that I've owned a number of years and recently noticed the rubber on the stands and speakers has gone very sticky.its quite horrible to touch.. Does anyone know of any way of curing it or if Dali will be of any help if i contact them?
Many thanks for any replies.
rccarguy2
Rubbing Alcohol will remove the sticky residue but that rubberised plastic coating will be removed..it's happened to my remote controls and saitek joystick.
I used some sanitising hand lotion that had alcohol in the ingredients that worked
flobrecht
Hi, I have exactly the same issue with my Fazon F5, in addition also the rubber on the bass-reflex opening is sticky. I don't think there is a simple cure for this. Have you contacted Dali in the meantime?
rccarguy2
If it's rubberised plastic you can use alcohol it'll remove the rubberised coating finish and take it down to the plastic
