Dali Concept 2
Discussion in 'Home Cinema Speakers' started by vag2010, Nov 17, 2004.
  1. vag2010
    vag2010
    Hi !I' m new here. I would like to ask you a question. Has anybody heard or read about the new DALI speakers CONCEPT 2 ? Are they good speakers for music and home cinema? Can they fill a medium room? Do you now better speakers in this category than DALI ?
  2. vag2010
    vag2010
    Please help me. !!!!!! I don't know if i should buy them.!!! :confused:
  3. aquapiranha
    aquapiranha
    My advice to you is simple, find a dealer and have a good long listen. This is the only way anyone should buy speakers, it may be too late after a couple of days when you realise they are not right for you. Most reputable dealers will let you have them on home loan which is even better. However, if you are buying secondhand.....
    aquapiranha :)
  4. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    100% agree. The only way to know how they will sound is to try them in your room with your equipment - everything else is guessing.
    Dali have a good reputation btw
