dalek voices
Discussion in 'Satellite TV, Sky TV & FreeSat' started by captainfearless, Sep 10, 2003.
  1. captainfearless
    captainfearless
    Mar 20, 2003
    63
    11
    hi, as i'm sure many of you do i mix sound from my ntl box through
    my home cinema amp ,(sony str db 780) and listen in normal surround mode.this is fine with video tapes,but with ntl if you
    listen close to the speakers the voices are garbled,mashed,dalekesque and obviously wrong.
    anyone else have this prob and know how to resolve please?.
    the captain
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,109
    Rainham Essex
    +2,381
    Can you give us a list of all equipment and what leads are used to connect each of these boxes together.
    It sounds to me like the amp is receiving 2 sets of audio, one slightly delayed from the other.
    Mark.
  3. captainfearless
    captainfearless
    Mar 20, 2003
    63
    11
    thanks mark,
    here goes..
    pace ntl box t.v socket scarted to sony t.v kv32ls,audio lead (wired into scart )to tv/sat in on amp. humax f1 dv3 mpeg2 sat box t.v socket to front sockets on t.v.vcr socket on humax to ext 1 on philips vcr vr 608.vcr audio leads into video in on amp.dvd player
    tosh sd 100e scart to t.v and audio leads to dvd in on amp.
    the garbled,echoey sound is on both the ntl and the humax(astra two )box.the modified scart was done by my local dealer and is not a d.i.y quickie!.
    cf
  4. taimur
    taimur
    Jan 9, 2003
    512
    19
    Glasgow
    have you tried different surrond modes - eg DPLII v DTS:Neo6, etc.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,109
    Rainham Essex
    +2,381
    Theres 2 possabilities I can see with your connections.
    1. Some TV's share the front AV & scart as a single input. You have a box plugged into both of these. Try unplugging the front AV on the TV.
    2. Try and get a video only scart lead for the NTL box. Some TV's output sound via the scart sockets. Are there no Audio output phono sockets on the NTL box?
    Mark.
  6. captainfearless
    captainfearless
    Mar 20, 2003
    63
    11
    thanks mark
    unplugged the front av lead- no joy.tried a regular scart ,and also
    did phono leads direct from the sat box to the amp,but still
    mangled,tunnelly audio.
    you only notice it if close to the sattelite speakers ,it also occurs
    with the astra 2 broadcasts so its not an ntl issue.yet video and dvd come through clear and correct.
    :confused:
    any other ideas?
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,109
    Rainham Essex
    +2,381
    My only other thought is that it may be a fault with the amp. Try plugging NTL into a different input. Also try plugging the analogue output from your DVD player in and see if this gives the same result with the same settings ie if you use DPL2 for NTL try playing back the analogue DVD sound with DPL2.
    Mark.
