daisy chaining telewest and xbox
Discussion in 'Cable TV & Virgin Media TV' started by zedzed, Aug 27, 2004.
  1. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    Hi there,
    Don't think that this has been posted before - so here goes :cool:
    My telewest (pace) box is connected to my TV using the RGB scart. My xbox is plugged into the second scart socket on the pace box - and hence "daisy chained" through to the TV.
    I'm wondering - am I reducing the xbox signal to a composite connection by doing this? (I've read the 2nd scart on the pace box is composite only??)
    My current TV is so kak that I can't really tell the difference - but I'm about to purchase a plasma :D and want to make sure I hook it up the best way that I can (perhaps by not daisy chaining scarts).
    Any ideas people?
    Cheers,
    Zed
    p.s. No suggestions of modding my xbox and going for component please - that's for some time in the future when I've paid off the plasma :smashin:
  2. Fernsehman
    Fernsehman
    Try asking customer.support{at}pace.co.uk
  3. zedzed
    zedzed
    Jul 12, 2004
    821
    +13
    If no one here knows I'll give them a go :thumbsup:
  4. zedzed
    zedzed
    Jul 12, 2004
    821
    +13
    For info - I now have my plasma and I daisy chain the xbox through the telewest box. This goes out to the plasma via an RGB to VGA convertor which will only convert RGB pictures. I get a picture on my palsma when I turn on the xbox - so the telewest box must be passing through the RGB signal :)
    ZedZed
  5. y220186
    y220186
    Dec 24, 2004
    38
    Ive done the same thing with my Xbox and gamecube, tried both on a Toshiba 36" and noticed no difference at all.
  6. jammyb2004
    jammyb2004
    Apr 12, 2004
    1,113
    63
    +113
    i believe that if something has 2 scarts, and it has the "pass through" ability, it'll "pass-through" all the signals, RGB included.
    but thats only through experience of 2 VCR's, a DVD recorder and a panasonic sky box (they all managed to let me play Burnout 3 at 60hz in RGB mode on PS2 in pass through mode of each machine)
    hth,
    jammy
  7. shyewei
    shyewei
    Dec 11, 2002
    5,510
    London
    +201
    Hi zedzed,
    Had the same problem. The Telewest box will loopthrough RGB signals from whichever source (Xbox in this case). The quality will be better than running it through composite or svideo (in my experience).
    As to whether or not there is any appreciable drop in quality I can only say I haven't noticed it myself.
    Hope this helps :)
