MasterMak
Ok, i'll try keep this as simple as possible.
I have 1 hdmi 4x4 matrix
And a much cheaper 2x4 matrix
Both take 5v power supply
My question is can i connect them together by having one of the outputs to the inputs of the other and vice versa.
My main concern is passing too much power through to the cables and damaging the tv's/projector/monitor
I might also use a cat5e over hdmi adapter for one of the connections although i don't think this point should make a difference in this situation.
I would appreciate any advice on this topic, in particular the issue of sending powered hdmi signals through the matrices. Can it cause problems?
