Daft questions, sorry
Discussion in 'Freeview & YouView' started by kingcobbler, Feb 3, 2014.
Tags:
  1. kingcobbler
    kingcobbler
    Jul 27, 2004
    1,192
    48
    +61
    Looking at getting a device for my mother to hook to her new TV.
    Is the youview whats she needs?
    If I buy the YouView with no external subscriptions, will she
    1) be able to watch all freeview channels
    2) record all freeview, inc series links etc
    3) If I hook up her BT infinity then the catchup bursts into life enabling her to go back 7 days in the epg?
    4) no ongoing costs
  2. snaithg
    snaithg
    Apr 7, 2006
    3,187
    +623
    Yes, Yes, Yes, Yes.
    Does your mother have any broadband at all? High speed broadband is not essential, catch-up TV will probably work ok with normal speed broadband, it does for me!
    Without any broadband at all, I don't think that the Programme guide will work properly and the box may not initialise correctly. I may be wrong though.
    Graham.
  3. kingcobbler
    kingcobbler
    Jul 27, 2004
    1,192
    48
    +61
    Thanks Graham, I worded it badly. she already has BT Infinity. So I'll either run an ethernet cable directly from the homehub to the youview box or use a pair of spare 200mbps homeplugs.
  4. snaithg
    snaithg
    Apr 7, 2006
    3,187
    +623
    This is what I am currently using. Will run a cable when I get the time!
    Graham.
  5. VisionMan
    VisionMan
    Nov 17, 2012
    2,877
    137
    +1,028
  6. VisionMan
    VisionMan
    Nov 17, 2012
    2,877
    137
    +1,028
    The box will initialise OK, but the programme guide won't, as it uses a combination of both aerial and BB signals for its info.
