Daft Question
Discussion in 'Blu-ray & DVD Players & Recorders' started by CLoNeR, Jul 3, 2004.
  1. CLoNeR
    CLoNeR
    Jul 3, 2004
    5
    Hello, i was wondering if it is possible to connect my dvd to a tv that has no scart connection. my dvd has s-vhs, composite and scart outputs and i have crates full of all sorts of audio and video leads, but i dont if its at all possible to do. Cheers.
  2. Will K
    Will K
    Dec 16, 2003
    362
    19
    Sussex
    What connections does the TV have?
  3. Fatti
    Fatti
    Oct 22, 2002
    665
    Worcester
    +40
    If your TV only has a aerial (UHF) input, you should be able to use something like THIS RF MODULATOR to do the conversion.
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,403
    2
    In a secret location with Jennifer Lawrence
    +10,340
    Moving to DVD players forum.
  5. CLoNeR
    CLoNeR
    Jul 3, 2004
    5
    thanks for your help, i will look into get one of those. i should really buy a new tv but its just for my daughters room, i thought i'd make use of my spare dvd player. thanks again.
