Daft desk question.
Discussion in 'Desktop & Laptop Computers Forum' started by Pack Dude, Jul 2, 2004.
  1. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    Im thinking of buying a new computer desk, This one. The thing is the desk comes in a left and right hand verison and i don't know which is which :confused: I need the one in the pic with the drawers on the right.
    Thanks for any help.
  2. HarshKarma
    HarshKarma
    Jun 28, 2004
    82
    9
    Ashford, Kent
    Hi pack man,
    Realise this is a week late but ...
    Looks like a right hand version but it's a little difficult to tell given the angle of the photo - £285 each seems a bit expensive though?
    Why not try http://www.viking-direct.co.uk - I've just got 2 ergonomic desks from them, 1 left, 1 right for about £310.
    Although it says self-assembly they actually built/installed them. I didn't want to ask if it was a mistake incase they changed their minds!
    Ed
    Edit:
    Found the correct url: http://www.viking-direct.co.uk/catalogFamily.aspx?ID=75601782&CID=100
  3. Garrett
    Garrett
    Apr 21, 2001
    41,194
    2
    167
    The best thief you’ll never see.
    +7,118
    It depends where you planning to put your computer and how much you would use the draw compared to the computer, floppy drive and DVD/CD tray if you put it on the other side.
    As the draws are on the right I would say it is a RH desk especially if you are putting a tower system aside it.
  4. Pack Dude
    Pack Dude
    Feb 6, 2002
    876
    Lost In Space
    +98
    :oops: I just noticed these replies, thanks for your help :) I did order the desk I had asked about and it was the one I wanted. With the bit that holds the monitor on the right. I also had an order code that gave me 20% of any order that weekend so it was a little cheaper than on the site.
    Thanks for the link HarshKarma it looks like a nice neat desk but im happy with the one i got.
