Daewoo dvg-6000 Macrovision hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by petrosp, Jun 1, 2002.
  1. petrosp
    petrosp
    It's easy to disable the macrovision on the particular player. No need to flash the firmware with a DVG3000N or DVG5000N !!!
    Macrovision off hack:
    1. Start playing disc - macrovision is enabled.
    2. When the film starts press v-mode on the remote control changing from video - rgb - yuv and back to video!
    3. Macrovision is off, unless you press stop or go back to the menu or in the setup! Thats really easy.
    You can even skip back to the first track press pause disable macrovision and start recording.
  2. normski
    normski
    hi
    i have tried this hack on a dvg 800d but does not seem to work any ideas i thought these two players were the same just the spec is a bit different
    normski
