Daewoo DR2100P - 5.1 output?
Discussion in 'Blu-ray & DVD Players & Recorders' started by davidwmorris, Dec 26, 2006.
  1. davidwmorris
    davidwmorris
    I currently have a 5.1 surround sound system, with a DVD player. The plaver has the 5.1 surround sound output on the rear. I want to upgrade to a Daewoo DR2100P DVD recorder. Does anyone know if it has the 5.1 output connectors on the rear?
  2. Frosty Predator
    Frosty Predator
    Dec 10, 2005
    107
    +7
    A bit late I am sure but the answer you were after is that it has a digital output by way of a coaxial socket so if you have a decoder then you will be OK.
    Fantastic budget recorder, Asda are selling at the moment for £69 and it even has progressive component output for the HD tv and is dual format.
