DAEWOO DP-42SP from Richer Sounds
Discussion in 'Plasma TVs Forum' started by ntranced, Aug 12, 2004.
  1. ntranced
    ntranced
    Aug 12, 2004
    11
    Just bought a DP-42SP from Richer Sounds for £1400, after looking at the Techwood and a Goodmans model a friend got from Argos while they were selling them at £1499.
    While I'm extremely happy with it (albeit I'm no expert) I am troubled by the quality of the sky+ picture. DVD is outstanding, and I'm aware that sky+ do compress the picture a little etc etc (and it has settled a bit as the days go on as well).
    However, I was under the impression that SVHS was a better connection than Scart, and as the DAEWOO has no Scart connection (has virtually everything else) I have no choice but to use SVHS. Is there a better way to do it? Can I get a Scart board? is there a Scart to RGB lead or something? Or will it not make any difference anyway?
    Thanks in advance, haven't seen the Daewoo mentioned on here a lot so if anyone does want any info on it for some bizarre reason feel free to ask ;)
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    My understanding is that SCART is a connection specification not a video signal standard. Typically SCART cables can carry composite, S-video or RGB signals with composite being the crudest form of signal and RGB just edging out infront of S-video in terms of PQ. Ignoring VGA and the latest formats of DVI/HDMI usually the best pictures come from a component feed (3 RCA phono connectors usually coloured red, green & blue). So whilst your Daewoo does not have any SCART sockets, strange for a euro spec set, you should be able to make use of the other sockets to good effect assuming they're not all composite inputs (single yellow RCA phono connector).
    S.
  3. ntranced
    ntranced
    Aug 12, 2004
    11
    Indeed. But bearing in mind my lack of a physical Scart socket on the plasma iteslef, how would you suggest I best make a connection from my sky+ ?
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    What connections does it have? It's hard to find a spec for this one, no web info to speak of. List the connectors, and a suggestion will be forthcoming. S-VHS is not too shabby usually, but can be improved upon.
  5. ntranced
    ntranced
    Aug 12, 2004
    11
    It has 1 PC/VGA input, 2 component A/V jacks (RGB?), 2 S-Video Inputs and thats it (excluding the speaker outputs and an RS-232C port).
    I know there are scart -> component cables around, I just don't know if this will be worth buying if it won't improve on the quality from the S-Video?
  6. bifkin
    bifkin
    I tried the Keene syncblaster scart to 5-BNC connector on my daewoo dp42sp and it didnt work at all ,tried 2 cables, maybe it has no support without the Daewoo tuner box which has scart in and can be bought from daewoo. Help line : 0870 1002525 (they will give info and contact details to whoever is selling the tuners)
