Daewoo DLP17D3 - Does Anyone Know/Have This Set And Can Help!!!
Discussion in 'LCD & LED LCD TVs Forum' started by jeimuzu_uk, Oct 22, 2005.
Tags:
  1. jeimuzu_uk
    jeimuzu_uk
    The Daewoo DLP17D3 was added to Empire-Direct's website last week and as i've been informed is from the daewoo's new DLP range. Problem is there's NO reviews around for it, google ain't much help and I'd really like to find out more about the set.
    I've been onto daewoos website but they only have the last years 17" screen model on there.
    It seems like a good little spec for a 17" lcd for £300 so can anyone help me in finding out what the response time is, if it's a good set for the 360, and does it actually have a HDMI input?
    If anyone can recommend this set or even just take time to look at the spec and comment i'l appreciate it.
    Link to the LCD!
  2. jeimuzu_uk
    jeimuzu_uk
    Take it the answer is no then? :lease:
  3. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    I can't comment on the TV as I have no experience with one or read anything about it anywhere. I would however question the fact that it says HD ready yet mentions nothing about component inputs or an HDMI/DVI HDCP input.
  4. igauk
    igauk
    Apr 8, 2005
    132
    Glasgow
    +6
    Well, the spec ticks the right boxes but I'd email Empire Direct and/or Daewoo and ask if its DVI or HDMI and what the response time is (which would be important if its mainly for gaming). You could order it and if it isn't suitable return it within 7 days as is your right under the distance selling regulations. If it's going to be mainly used for gaming, why not save a few bob/get more for your money with a 17" or 19" monitor?
    See
    http://graphics.tomshardware.com/display/20050720/index.html
    and
    http://graphics.tomshardware.com/display/20050606/index.html
  5. chrislad
    chrislad
    May 6, 2005
    5,867
    83
    Rep. of Ireland
    +153
    I had a Digix 20in that went kaput, and I got this in exchange. Though it's a smaller TV, I think it's much better. The picture quality is clearer, plus the native PC resolution is 1024 x 768 and not the **** poor 640 x 480 that the Digix had. I'm not really up on the technology behind better pictures or what not so I'll just list what ports it has on the back if that helps. I know it supports component, so I have to get one of those for my Xbox.
    You have the following ports
    S-Video
    Standard Red, White, Yellow connection for sound and video
    Component (Pr, Pb,Y, R-Audio-L)
    VGA
    Scart
    ANT
    PC Audio
    There's no digital sound connection like the one on the Xbox Advanced Scart.
    Great TV for a bedroom though, which is how I use it.
  6. Orias
    Orias
    I've been looking at this too for my Brothers' Birthday in a few days. The good news is that it's mainly for his bedroom, so cheers for your review Chrislad, it was very helpful. The only think that I really want to know is does it have a headphone jack?
    I actually work in the gaming industry, and do a lot of work on the X360. If this is any good, then I may well get myself one too as HD really does completely change the games. The specs certainly are very impressive for a small set. I have to use a REALLY ugly 24" SONY HDTV at work for the Xbox 360 work I do, and I think it cost around £700!!
    Any rapid replies would be great as I need to get this delivered by the 30th if I'm going to get it in time for his Birthday!
    Cheers, Orias
  7. chrislad
    chrislad
    May 6, 2005
    5,867
    83
    Rep. of Ireland
    +153
    Orias, yes, there is a headphone jack.
  8. Orias
    Orias
    Cool ... thanks Chrislad,
    Going to hit the magic 'buy button' now then :D
    Cheers, Orias :smashin:
  9. chrislad
    chrislad
    May 6, 2005
    5,867
    83
    Rep. of Ireland
    +153
    You won't be disappointed. I'm really loving it. All I need are my component cables and I'm sorted. Like I said, it's a great bedroom TV. Note that it is surprisingly heavy for such a small TV. It was heavier than my 20" Digix!
