Daewoo Colour Problems
W
WBC
Guys,
Just bought a Daewoo Twin Tuner PVR and am having issues with the picture flicking from normal colour to black and white then back again in about 1 second.
It happens alot. Picture quality is good and signal seems ok, its not particular channels, it seems to do it on all of them :mad:
Any ideas?
Stace :D
PhilipL
Have you checked the SCART cable? Make sure they are fully home or remove and re-insert the sockets a couple of times to wipe the contacts.
It seems like you are using S-Video (aka Y/C) via the SCART cable and the Chroma signal is intermittent. You could try RGB or composite as a trouble shooting exercise, if it still does it on these settings and manifests in the same way I would suspect the unit being faulty.
Regards
Phil
