Daewoo 9000s5 on amazon uk at 59.99
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ros, May 28, 2003.
  1. Ros
    Ros
    May 28, 2003
    3
    http://www.amazon.co.uk/exec/obidos/ASIN/B00009MGDY/ref=ed_xsoc_ce_h__1_1/202-2998455-6360663
    Does anybody know anything about this dvd player? It is listed as
    bestselling, for £59.99 but I can't find a single review on the web,
    or even find out if there is a scart connection, does anyone own this model?
    Daewoo Electronics UK say that it must be an import as it is not a model produced for sale in the UK. As my TV only has a scart connection I need to know if there is a scart on this Dvd player before i spend hours looking for strange scart adaptors!
    Ros
  2. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +9
    To be honest I would not touch it with a barge pole and I did not even look at the spec, Look round for a Toshiba SD you can get a multi-region SD210 from Richer Sounds for £80 or a SD220 for not much more - http://www.richersounds.com/index.php?f=itemdetl.php&p=205582 why bother with an unknown item?
