Daewoo - 6cm black band at top, bright thin line
N
nig28
Daewoo GB2898ST has just started to display an extra 6cm of black above picture, normal at the bottom. And almost at top of picture a bright thin line.
Is it a simple fix? And is it likely to make it through xmas?
Many thanks..Nigel
paul-av-tech
If this is a widescreen, try it in the other screen format modes. If the picture geometry is OK in other modes or wildly out, it may be software corruption.
If the black line is unmoving then you have a fault in the frame stage and need an engineer to look at it.
The Queens speech is available via podcast if it does die :)
N
nig28
The black line does move (get a little bigger), and the bright line is in the top of picture. Bottom of picture ok.
So maybe sounds like a frame fault, but just at the top. It is my sisters TV, so I will see if it is still working boxing day.
Many thanks..Nigel
technospark
hi nig28
i agree with jaycee that it is the frame output ic and a few other componants it should be a straight forward repair
