Daewoo 42inch connection to dvd player problem.
Discussion in 'Plasma TVs' started by caw001, Jun 18, 2003.
  1. caw001
    Hi, as the title suggests I have a 42inch Daewoo, I have this plugged to a portable panasonic dvd player (lv60 I think?). This is connected via svideo.
    The problem is that if I play region 1 dvds the picture is quite fuzzy, region 2 are fine. I can use the dvd player connected to my other phillips design line tv with no problems.
    The dvd player doesnt seem to have any pal/ntsc selector etc and i'm told the tv automatically sets itself. It has been suggested that the dvd player is outputting in pal60 which the tv cannot understand properly?
    If I cannot do anything about this then I'm happy to buy another dvd player but I dont want to find the same problem occuring.
    Any ideas gratefully recieved.
