Daewoo 42" Plasma
Discussion in 'Plasma TVs Forum' started by fatcockney, May 8, 2002.
  1. fatcockney
    fatcockney
    Anyone got a Daewoo 42" Plasma TV connected to Digital Cable (NTL etc....)???
    I've tried all sorts of Scart to composite, SCart to S-Video cables, but I still cant generate a colour picture through the TV.
    Anyone else had similar problems?? The manuals are useless as has most of the tech help I've come across so far.
    Suggestions welcomed!!!!
  2. YYZ
    YYZ
    Is the screen set to "Auto" for its colour system. Check in the system menus that it is set to "Auto" (if available) or "PAL"
    The UK uses the PAL colour system, if set to NTSC, as used in the US then you will (I think) only generate B&W pictures from PAL source material.
  3. cyrus-t
    cyrus-t
    Feb 28, 2004
    181
    +16
    I've got what sounds like the same plasma and I've given up trying to connect my sky nox directly to the plasms (even though I can do it with my DVD player, and my Playstation2)........
    I just use the Tuner Box ....
