Dads Amp .
Discussion in 'AV Receivers & Amplifiers' started by Zog, Jan 15, 2003.
  1. Zog
    Zog
    Aug 16, 2001
    426
    Manchester
    +5
    Done a bit of research on behalf of my Dad who is looking to upgrade from PL to DD.
    Found The Yammy RXV430RDS @£199 from Super-Fi. It seems like a good deal.
    His priorities are RDS/DD/PLII.
    As amps in this bracket can collapse in price overnight (as this one has), is there anything else that I should be considering? Are there any other deals for this or equiv. amp knocking around at the minute?
    At £200 he is maxed out on his budget.
  2. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    Does the RXV430RDS have prologic II?
  3. Geezer
    Geezer
    Aug 5, 2002
    2,813
    68
    +25
    Just checked and so it does :blush:
  4. 7ThGuest
    7ThGuest
    Sounds as if it is just for TV/Movies, I don't think you will be dissapointed.
    I use to have the Yammy 496 and that was a cracking amp for movies. I am returning my week old Marantz SR4300 for a Yammy DSP AX630 (£270) also has DD EX, DTS ES/Matrix, NEO6 etc etc. I know it's a fair bit extra but a bit more future proof 6.1 et al.
    Regards
    7ThGuest :)
