DACSC8 speaker placement
Discussion in 'Home Cinema Buying & Building' started by Samari, Sep 5, 2004.
  1. Samari
    Samari
    I know that with a 5.1 system you are meant to have the rear speakers behind you and to the side but as my sofa is 90-degrees to the wall (I have to have it like this) It is not possible to have them to the side as it suggests on the Dolby site. So is it ok to just have them directly behind you and how far away should they be? My other question is this: Is it o.k to put the subwoofer underneath your sofa, between your feet, or are there any better places?
