DACs contribution to sound quality?
Discussion in 'AV Receivers & Amplifiers' started by braidkid, Apr 22, 2005.
  1. braidkid
    braidkid
    Hello,
    I recently purchased a Denon DVD-2910 player to go along with my Yamaha HTR-5790 receiver. I noticed a dramatic improvement in sound using 6 channel analog inputs rather than digital to the receiver. Bass is much tighter/less boomy and there is much more clarity in the highs. In comparison, using digital connection, the Yamaha sounds muffled, while using analog, the Denon sounds much more airy and detailed.
    I'm trying to figure out the weak link in the receiver and why analog connections sound so much better. I know that Yamaha uses AKM DACs while Denon uses Burr-Brown DACs. Could this be the difference I'm hearing? What else besides the DACs would contribute to the Denon's superior sound reproduction over the Yamaha receiver?
  2. Andy_Lee
    Andy_Lee
    Mar 12, 2005
    98
    Telford Shropshire
    You have hit the nail on the head. The DACs contribute a hell of a lot to the sound also bear in mind in the Yamaha the enviroment that the DAC's operate is more hostile in terms of more electronic noise from the electronics running the power amps etc.
    I have a 3910 and a 3805 and I use the Decoder / DACs in the 3910 for all processing except 6.1 DVDs and the sound is better this way.
  3. Kamakazie
    Kamakazie
    Sep 20, 2004
    542
    +22
    so using a 2910 and AX757 am i best to connect them using the 6 channel analogue and then make the 2910 do the prcessing or should i get both leads and experiment?!
  4. Andy_Lee
    Andy_Lee
    Mar 12, 2005
    98
    Telford Shropshire
    Well if you can justify the cost of some decent analoge leads it's alway's worth experimenting :D
    I had to buy the leads as I wanted SACD from the 3910 so I just tried what was suggested on this and other forums.
