DacMagic 2
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Mike-M, Oct 17, 2004.
  1. Mike-M
    Mike-M
    Oct 13, 2004
    1,376
    48
    Lincoln
    +39
    I have connected a Dac Magic 2 to my Marantz CD600 OSE and been disappointed with the result. But reading through the forums I think I know why and would just like to ask if I'm on the right track.
    I used coax connections for the cd to the dac and to the av. But from what I read I should use a coax from the cd to the dac and then an anologue lead from the dac to the av. Am I right?
    If so any suggestions as to a good quality anologue lead would be most welcome.
  2. 337GUS
    337GUS
    Nov 1, 2000
    764
    NE Scotland
    +41
    You are correct about the cabling, digital from CD to DAC, analogue from DAC to Amp, otherwise you are using the Amps DACs.
    Chord, Van den Hul, QED http://www.hificables.co.uk/
  3. Knightshade
    Knightshade
    Aug 6, 2004
    2,004
    +43
    Could try Mark Grant cables on this forum?
