DAC for coaxial output
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mrkjd, Jul 16, 2003.
  1. mrkjd
    mrkjd
    Does anybody know if there's a Coaxial (in) to Svideo or similar Digital to Analogue Converter?
    I have a Cable STB that only has a coaxial out (old analogue Cable TV) and I want to feed the signal to my plasma
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,264
    Manchester
    +756
    Surely your Coax-out will be an RF output with the audio & video somewhere around channel 36/38 UHF.
    Therefore, you would actually need a tuner for this (and it will be mono sound only).
    So you surely don't need/want a DAC (Digital to Analogue converter). A DAC (more correctly DENC for Digital ENCoder) is a device that takes 8 or 16 bit video (ITU-656 / CCIR601) and outputs RGB, S-video or Cvbs via its internal video DACs.
    See www.analog.com/video and select "Selection Tables" followed by Video Encoder Products for these.
    Please explain exactly what sockets exist on your cable STB (all of them) and we can advise further.
    Chris Muriel, Manchester
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    What you need is a demodulator to get the composite video feed out of the RF socket and the Audio out. RF is radio frequency modulated, you need the unmodulated signal for a plasma if you have no tuner module. (a VCR will do this)
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,264
    Manchester
    +756
    It's a pity he will still have sound in glorious mono :(
    Chris Muriel
  5. mrkjd
    mrkjd
    thanks for the reply guys ...... guess I'll be getting a Freeview box soon then!
