Dac amp and IEM virgin looking for advice
pixelpoacher
Hi peeps, can't really find any previous along the lines I'm investigating....
I've never had or been into headphones etc until lockdown. Had hifi before etc, but been listening to Spotify etc on my phone with some galaxy bud pros, plusses before that.
I am wanting to get much better sound quality but unsure which direction to go in.
Do I use the phone (S21 Ultra) as the source and just get some decent iem's, do I use the phone and get a dac and amp etc?
As the phone doesn't have a 3.5mm jack, do I get a DAP instead?
Any advice would be greatly appreciated, listen to a wide range from Floyd to classical and I do like a bit of bass....
Darrin
Steven
Senior Moderator
In ear monitors are, mostly, easy to drive. Focus the budget on the IEM. The thread by @gex23 about moon drop is a good start. I use the Shure SE846 straight from a smartphone for example, that model is notoriously easy to drive
Modern smartphones without a 3.5mm jack: buy a USB C to 3.5mm adaptor, which in itself is a digital to analog converter. Many available on the market for all budgets. Even the Apple I gets good reviews for sq
Digital audio player: special use case, have to know you will use it
Portable DAC amp: as with the USB C to 3.5mm form factor, can pull double duty with laptops or computers. Suggest looking at the iFi audio battery powered devices
pixelpoacher
Thanks for that, does the USB DAC have a big impact on sound, is it better to buy the best possible to allow the IEM's to shine even on Spotify?
Steven
Senior Moderator
Yes,
It is simply my personal financial experience at the budget end it is best bang for buck putting most of the budget into the in ear monitors
In your case you are forced to buy a USB C to 3.5mm DAC amp because your smartphone has no built in headphone jack. So I suggest 80% to 90% of the budget on the IEM and 10% to 20% of the budget on a dongle.
Adding a nicer DAC amp later is fine to help refine the whole package. But a nicer DAC in my experience cannot polish average earphones / headphones
In addition to moon drop there is also tin audio getting good reviews for budget models
The alternative are Bluetooth headphones. Wireless BT headphones have a built in DAC and your smartphone is the BT source. That simplifies the chain
