Question dab radio
Discussion in 'Hi-Fi Stereo Systems & Separates' started by jack45, Apr 2, 2018.
  1. jack45
    jack45
    Dec 2, 2007
    27
    3
    after listening to dab radio for maybe 3 hours or more it starts to distort in the background with a low-frequency popping sound lower in volume than the music but just audible it is on other channels so I know it's the tuner never does it when playing CDs
    if I switch to cd then back to dab it goes away
    anyone any ideas
  2. Cornish Dave
    Cornish Dave
    Dec 20, 2017
    404
    28
    Northumberland
    +93
    Sounds like poor reception to me. Do you live in an area where reception is poor? Has anybody else got a dab radio you could try to see if something similar happens? Personally I think dab is rubbish although it works ok in my car. I am a big fan of internet radio gives me very few problems.
  3. JayCee
    JayCee
    Jan 20, 2004
    23,362
    Lanarkshire
    +2,514
    Sounds like a faulty radio.
    If it was poor reception it would cut out completely or intermittently, not after 3 hours.
  4. Cornish Dave
    Cornish Dave
    Dec 20, 2017
    404
    28
    Northumberland
    +93
    Mine used to work for a while and then make that noise. Switch it off and come back in an hour and it would be ok but then would start again.
  5. jack45
    jack45
    Dec 2, 2007
    27
    3
    I thought bad reception would cause complete drop out not background noise
    thought it may be a component fault but 3 hours or more seems a long time if something is overheating
  6. Cornish Dave
    Cornish Dave
    Dec 20, 2017
    404
    28
    Northumberland
    +93
    Mine used to make that noise on a station with poor reception. Sometimes this would appear after a period of listening or straight away. There was no specific time such as 3 hours. I live in an area with poor dab reception and understood this was the reason. Personally I think dab is rubbish I have no problem with connecting on the fm frequency. Having said this my car has a dab radio and this works almost perfectly.
  7. dannnielll
    dannnielll
    Sep 16, 2017
    1,793
    113
    ireland
    +758
    Bad reception on DAB produces blackouts and silence, poor reception leads to squealing and squelching noises.. and that's just the radio....
