Question DAB / Internet Radio
cjc1664
I'm looking for a DAB / Internet Radio with Spotify Connect and DLNA capabilities for the kitchen, probably around the £150 mark.
Does anyone know the difference between the Roberts stream 93i, 207 and 217? I can't really find a huge amount of information about them, particularly the 217.
Would consider alternative brands if anyone has a good recommendation.
Thanks!
Dave Cullen
By coincidence I was looking at the 93i today and comparing with similar priced models.
The sound was significantly better than anything else that I heard - great bass and really good mid and top end. The only issue I've got with the spec is that it isn't portable (i.e. battery backed-up power) otherwise I was ready to take it away!
Sorry, I can't help on the other models.
Clem_Dye
I was looking at the 93i and was really tempted, but it's an absolute faff to connect an external dab aerial - you have to do a lot of messing around to get the external connector exposed. In the end I went for a Panaonic SC-HC29DB which has an external dab/fm connector, and stream stuff via bluetooth from my ipad. Great sound and £70 cheaper from JL.
Clem
