DAB in Mansfield ??
Discussion in 'Music Streamers' started by HMHB, Feb 16, 2003.
  1. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    Is there anyone from Mansfield here who's got DAB and can vouch that the reception is OK ? When I go to the web-site for DAB it tells me that I might be able to get it - very useful :rolleyes:
  2. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    Reception's fine in Sheffield ( Don't know whether that's close enough for ya)
  3. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    Not that this completely answers your question ... but can you arrange with a dealer that if you don't get reception you can return the tuner. If nothing else ... you could always try buying the one that Argos sells, see if you get reception, and return it whatever so you can buy the tuner you actually want.
    Victoria
  4. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    I was thinking of getting a PCI card type for my computer so I don't think that taking it back is an option. I think it's worth the risk though as I've checked on another site which says that there is a high chance of receiving but I may need an outdoor aerial.
